On Board Water Pump
Sir Roger
I have a Shurflo and as Chrisn says it will run on for a few seconds after taps are closed and the system re pressurises. Also every so often it will pulse as pressure is maintained.
I think you may have cracked it.
It shouldn't really need to pulse from time to time, unless there is a very small leak, perhaps a tap dripping, or a joint just starting to weep. Perhaps the only advantage of an audible pump is that it does give warning in this way
The pump may pulse once in a while if you have the water heater on, and either used no hot water or just a small amount, and the turned the heater off. as it cools the wtyet will contract reducing the pressure, so the pump may just pulse to rebuild the pressure
Thank you all for your suggestions which obviously most of them I have tried to get where it is now. To be fare I will now more in 11 days time when we go off again. . Its been a bit of a task but hey its a bit more knowledge that I can share with others. Thanks again everybody .
Regards Sir Roger .
Regards Sir Roger .
You've now got 10 days to fix it before you go, ๐Ÿ˜— :lol: ๐Ÿ˜—
Come on Sir Roger you can fix it....there's a good lad ๐Ÿ˜›
