On board water tanks
Jul 23, 2008
84
My caravan has a on board water tank,is there any kits i can use to connect it to a pitch water supply
Oct 24, 2007
199
Hi Valeter, I'm no expert on onboard tanks (got my first this spring) but the dealer did mention to me that there are basically 2 varieties: one vents to the outside via a plastic pipe through the floor and the other is open at the vented at the top and if overfilled would flood the caravan!
Nov 6, 2006
731
5
18,885
If your van uses Whale water components, then the tank is filled by pumping from your aquaroll, via the sidewall connection, until water exits the overflow.
To fill the onboard from the pitch supply, you will need a Whale Watermaster hose/connection kit. The connector block simply fits to the same sidewall connection point, but has clips to hold it place, to prevent mains pressure forcing it off. This is because you will find a 2 way tap between the sidewall inlet, and the onboard tank fill point. The second position stops the tank filling, and instead pressurises the van water system. However, the Watermaster block contains a pressure reducer, which has the effect of reducing the flow-often below that of the onboard pump. For this reason, we use ours just to fill the onboard tank
