Deli Dave_374550494 said:we use a spring loaded shower head cant find the link but someone kindly posted it on here.It saves you messing around and moving the temperature selector and makes the supply of water last longer.We put the gas and electric on together to reheat quicker and it seems to work well.HTH
http://www.practicalcaravan.com/forum/technical/calling-kath-at-swift
Hi Dave + Parksy, the link does'nt actually show anything, it only mentions a trigger style shower head.
Any other idea's? cheers chappies
Kev
Link forwarded by request from the Technical section where Dave had inadvertently posted it.
Parksy (Moderator)
Val A. said:And make sure she never has a shower whilst you're not there to refill the aquaroll!
If the pump stops when you're all soaped up it can be a real problem! The one and only time I used the caravan shower (in eleven years) it ran out of water whilst my OH was out! Shower gel and shampoo takes a lot of rinsing off with just what's left in the kettle!
LMH said:One thing we do is (if you're on hookup) is when you've finished in the shower/bathroom, put a fan heater in the bathroom (on the floor) and close the door and let it run for about 10-15 minutes
Parksy (Moderator)
LMH said:Surely that's common sense isn't it?![]()
Gagakev said:........On another note do you know where the "LINK MAN" went havent seen or heard from him in a long while?
OmOnWeelz said:We swapped the shower head for a small fine spray head that lets less water through it. With electric and gas on we can both shower easily, we have an internal tank that auto fills from two aquarolls when not on mains water hook up. Our bathroom has a blown air heating vent. close all the other vents, turn the heating on and the shower experience is always warm and with the heating on full you can air dry and save on towels![]()
