- Apr 19, 2023
- 161
- 120
- 1,635
What product do people find works best to clean out waste water pipes from sinks and shower? Thanks.
Puriclean or Milton . Don’t leave any of the cleaning products more than say 15 minutes in the hot water tank . They corrode stainless steel. And rinse thoroughly with clean water. Also check the tap end filter mesh. They can clog up.
Personally, I use caustic soda/drain cleaner. Just don't leave in the pipes too long.What product do people find works best to clean out waste water pipes from sinks and shower? Thanks.
However domestic drain pipes are normally metal, but caravan is plastic so one need sot be careful in case there is a reaction between the two.Some domestic drain cleaners are either thixotropic, some form of gel and or foaming based, these are intended to linger throughout the pipework, doing their thing till flushed away.
Most modern domestic drain pipes are plastic so shouldn't be an issue.However domestic drain pipes are normally metal, but caravan is plastic so one need sot be careful in case there is a reaction between the two.
The Drain Cleaner version is safe in plastic pipes. You'll be hard pressed to find metal drain pipes in houses. I've used the Caustic Soda version for years in my caravan without issue. Block the outlet, pour down drains, leave 30 mins then rinse - easy.However domestic drain pipes are normally metal, but caravan is plastic so one need sot be careful in case there is a reaction between the two.
i think you are out of touch, copper wastes were starting to disappear I would think in the 1970s, and I further expect most homes of pre then have had a kitchen revamp or a few since then.However domestic drain pipes are normally metal, but caravan is plastic so one need sot be careful in case there is a reaction between the two.
My Lunar was the same, but only because I changed all the ridiculous convoluted pipes and introduced a fall.i think you are out of touch, copper wastes were starting to disappear I would think in the 1970s, and I further expect most homes of pre then have had a kitchen revamp or a few since then.
Our Hymer is factory built with what appears is pretty much domestic solvent welded ABS piping. Plus its all designed with a "fall", not the drooping between supports I have seen on another van, designed to sediment up.
I am racking my brain to think of a house we’ve had that had metal drain pipes. Our first house bought in 1974 had plastic which had evidently been installed to replaced earlier mid 1930s plumbing.However domestic drain pipes are normally metal, but caravan is plastic so one need sot be careful in case there is a reaction between the two.
Plastic isn’t invented where Buckman comes from. 😎🤪🤪🤪Most modern domestic drain pipes are plastic so shouldn't be an issue.
I recollect seeing plastic being installed for internal and external above ground drainage in the 60’s.i think you are out of touch, copper wastes were starting to disappear I would think in the 1970s, and I further expect most homes of pre then have had a kitchen revamp or a few since then.
Our Hymer is factory built with what appears is pretty much domestic solvent welded ABS piping. Plus it’s all designed with a "fall", not the drooping between supports I have seen on another van, designed to sediment up.
But have you not got plastic waste pipes connecting the big down pipe in your home?I was referring to drain pipes and not supply pipes. Our kitchen and bathroom outside drain down pipes are of a metal material. Our home was probably built in the fifties or sixties.
