Setting off on our first caravan holiday soon. We bought a used van which came with an air awning and various ground sheets and carpet.
I need advice on how best to go about laying the flooring on hard standing and grass, I think the pitch we’re going to is hard standing but the next could be grass.
I have a very large breathable groundsheet which is rectangular and a good 12” bigger than the footprint of the awning. Then I have what seems to be a universal carpet/underlay which again is rectangular and slightly bigger than the awning. Lastly there is a set of fitted/shaped carpets which are clearly for the specific awning we have.
So am I right in thinking that the breathable sheet goes down first and pegged down flat, then perhaps the universal underlay/carpet if needed for extra cushioning and then pitch the awning on top leaving the underlay sticking out beyond the awning footprint.
Then peg the mud flaps of the awning down inside pegging through the ground sheet and then finally lay the fitted carpet.
ive got myself some 6” nails and washers for pegging down the ground sheet on hard standing and screw in tent pegs for the awning. We did go on a long weekend to try everything out and while I was fighting with the awning I heard a lot of noise from other visitors who were setting up, sounded like a hammer drill which I’m guessing they were using to drive in the pegs.
so is it the ‘norm’ to peg through the ground sheet which is sticking out outside the awning or do you try and fold/tuck it neatly inside? Our air awning is not a straight rectangle and curves in at the ends so the corners of the ground sheet stick out quite a bit.
