Hiya,
I'm an utter newby having recently bought a Fiat Adria 2016 plate. Its been idling over the winter but I've run it and all has been fine until this week when my battery went flat. So replaced that. I then filled the water tank to slush it out (with appropriate tank cleaner) and when I tried to turn on the water to transfer it to the grey tank, it all poured either onto the ground from under the tank or all over the bathroom floor.
So ive been back to the manual and worked out about the frost prevention button. Reset it ( I think), refilled the tank but I still have zero water coming out of the taps. It seems I can either have it pouring down the drive or not at all.
I know I'm a novice and its probably me..... but where am I going wrong?? The manual says turn the power on, turn the taps on full (hot) but there is no pump power or anything. Am I being a total dimwit?! I'm sure there's an easy answer that I'm not seeing....
Can anyone help? Its meant to be going out on Tuesday and I'm running out of time to fix it :-(
Thank you
Thank you
