- Jul 18, 2017
- 16,485
- 5,285
- 50,935
Our washing machine has a water protection box on the end and it sticks out away from the wall as the water outlet is horizontal. To hide the pipes we have a radiator type cover box so a bit of a hassle getting it flush to the wall.
Is there a elbow connection that we can can screw onto the existing water mains outlet and then connect the washing machine to the elbow connection? Most of the ones that I find seem to have a compression fitting which is no good to us. An elbow connection would be simpler than paying a plumber to fit another tap. The other option is a T connection as that will be parallel to the wall, but how do you block up the end that will not be used? Thanks for any advice.
