power supply unit
Mar 28, 2009
I press the test button on my power unit & it isolated the power when I came to switch the power back on it wouldn't.
Can a test switch jam?
May 2, 2006
229
18,585
Steve,
My first assumption would be that the circuit breaker is working correctly and doing its job. In those circumstances it has detected a fault condition (probably uneven power flow compared between the supply and return). I would consult a competent electrician.
Cheers
Mike A
46
19,185
Don't know about RCD's but MCB's when they trip only drop the lever half way down, it won't then reset if pushed back up from this position, it has to first be pushed all the way down and then back up.
Mar 28, 2009
Its fixed all I had to do was to pull all the plugs out of there sockets & reset. Thanks for all your help, Happy days :eek:
Jul 15, 2008
3,927
1,118
I would check you appliances by plugging them in one at a time just to make sure none has a fault.
One may have a leakage to earth!
Mar 10, 2006
3,274
47
Gary is correct, some rcbs require the switch to be taken fully to the off position to enable a reset.
If a circuit is faulty, i would expect the breaker to trip, as you have already checked the trip via the test button.
I dont see a problem.
