Hi evryone, i have one orange gas bottle in the caravan at the mo as my second one has just ran out, i am looking for somewhere where i can get a refill cheaply, i live at newcastle and i am just wondering does anyone recomend a place to go? Thanks
Mr Bell said:well what can i say, im learning as i go! i have a propane gas bottle, its a calgor orange. 4.5kgs, so i gather that is the best one to use. I am hoping to use the caravan as much as possible as thats why i have it. i have changed a gas bottle in the caravan which wasnt too hard to do. I have only done it once tho so my need to remeber what to do. BUT i know the gas bottle which is connected at the mo is full so no worries there.
Yeah sorry its a calor, sorry typing error, its red not orange and yes its has a threaded nut that screws on the gas cyclinder. I have a 4.5kg as it makes the noise weight lighter, if i start getting bigger bottles it will decrease the amount i can put on the front of the caravan! and increase the weight on the nose!Surfer said:Calgor Gas is an Canadian brand of gas and probably unavailable here. I assume that it a Calor gas cylinder that connects to system in the caravan via a threaded nut that screws onto the gas cylinder. I am a bit puzzled though as normally the calor gas propane cylinder is red, not orange. If it is a Calor gas cylinder, expect to pay about £20 for a 6kg refill. I would also recommend that you change to a 6kg bottle as per kg it is cheaper to refill than a 4.5kg bottle. Also lasts longer and will fit in the front locker on the caravan.
I dont understand?? i thought the bottle i have weighs 4.5kg?? how does a 6kg bottle weigh 10kg?? and how does that weigh less then what i have? im confused.TD42 said:Calor also do a light weight(Calorlite) 6kg propane bottle which comes in at @10kg total weight this is probably as light or lighter than your 4.5 kg steel bottle.
It is usually a direct swap for any Calor bottle but from a proper Calor depot
Mr Bell said:I dont understand?? i thought the bottle i have weighs 4.5kg?? how does a 6kg bottle weigh 10kg?? and how does that weigh less then what i have? im confused.TD42 said:Calor also do a light weight(Calorlite) 6kg propane bottle which comes in at @10kg total weight this is probably as light or lighter than your 4.5 kg steel bottle.
Sproket said:Mr Bell said:I dont understand?? i thought the bottle i have weighs 4.5kg?? how does a 6kg bottle weigh 10kg?? and how does that weigh less then what i have? im confused.TD42 said:Calor also do a light weight(Calorlite) 6kg propane bottle which comes in at @10kg total weight this is probably as light or lighter than your 4.5 kg steel bottle.
A Calor Gas CalorLight 6kg Gas Cylinder is made from lightweight steel,
the CalorLite propane cylinder is 49.7% lighter than the standard Calor 6kg cylinder and includes the Gas Trac gauge
Approx. Total Weight: 10.52kg
Approx. Content Weight: 6kg
Approx. Tare Weight: 4.52kg
Approx. Height: 487mm
Approx. Diameter: 246mm
The 3.9kg cylinder that you allready have will weigh in the region of 9.6 kg when full
The photo's below are of my calor light bottle,
Most bottles have there tare weight stamped on the plate near to the outlet valve
This bottle is stamped with it on the base ring.
So in here when full is 6kg of propane & it will weigh approx 10.42kg
When it's all used it will weigh 4.42kg
But i think you realy need to read this about using propane safely
They are difficult to get hold of but not impossible and worth the wait. You may have to pay a small deposit. My wife can easily lift the ligtweight propane bottle which says it all as it she is not a big person by any stretch of the imagination. Our local dealer in Worcester has some in supply.Mr Bell said:hi again, been looking at getting a calor light 6kg for my caravan and seems light they are in high demand, they seem to be very hard to get a hold of. Im going to keep trying but looks like i am not going to be able to get one.
Mr Bell said:good question i cant remeber what the regulator is, my dad had used it so i just used it. I know there are different ones but i dont know much about them in the sence what the differences are?
