Pride Apex Rapid mobility scooter mirrors 8mm thread
4,804
The wife wants a brighter one for the front now, so she can see the pathway easier, Her and Parksy didn't need them getting back from The Coachman at the Woosie fest , but then again there was a reason. 🍻🍻
2,668
Keep me updated on what you get (y)
5,552
I use these on my EV . It lasts ages on the low setting which gives a brilliant light, charge at home via a USB. The red bracket is capable of easily having two lights!
BB It is very easy to fit, although Hutch may struggle as it isn’t complicated enough for him🤪🤪 Both available from Amazon.
Nestling®Bike Light Set,3000 Lumens USB Rechargeable Bicycle Lights,5 Modes Waterproof LED Headlight Mountain Bike Light,Safety & Easy Mount Cycling Front Light & Rear Light
-7% £18.65£18.65
  • Wow
Reactions: Beachball and Hutch
2,668
-7% £18.65£18.65
Hi DD i will have a look it seems very reasonable and thanks for the information
2,668
Dead easy if you buy a couple of bicycle rear lights many will come with the plastic jubilee clip integrated. All you do is unfasten the clip, route it around the support of the scooter and then tighten it up using a screwdriver., or some have a rotary thumb wheel. The most difficult bit is synchronising the flashes between the two lights. (TIC) as you cannot press them both simultaneously. Literally it can take hours. 😱
Had a look i keep it in mind thanks for your input
