after winter drainage, on a coachman laser(just out of warranty).starting to re-fill after drain off, rigged up aquaroll, pump etc. symptoms are that the pump is continually running (there is water in the aquaroll)at this stage but no water at taps, no blockage from aquaroll to tank to drain off valve as water can be seen empting from aqauroll to drain off point.after constant running off pump a small amount of running water can be seen at shower, vanity sink and then kitchen sink. The pump led light is on at all times.help!!
