Has anyone had any problems with a Gaslow automatic changeover causing low pressure when connected to a fixed regulator on a Pageant series 5. When you take the changeover valve off and connect the pipe direct the pressure is fine.I've checked i've got the right model and you can blow through the valve alright without any blockages. I only use propane gas but when the changeover is connected the drop in pressure is quite dramatic even if you put a second burner on. Have even tried a different bottle of gas.
Thanks in advance
Thanks in advance
