Hi there,
My parents have a 1988 Bailey Pageant 2 berth caravan, and it seems to have developed a problem with both rear corner steadies.
When you lower the steadies into position, they will touch the ground but you then can't get that final turn to secure them firmly as they just keep slipping, and will not tighten up.
Also when you stand in the rear of the van you will suddenly feel a bump and the caravan will drop an inch or 2, when you go outside the corner steadies are no longer touching ground.
Any help, advice or suggestions on this would be gratefully received, also as to likely costs involved and how simple it may be to repair.
Many Thanks
Andrew.
Many Thanks
Andrew.
