DaveA1 said:
You well only need to change the regulators, they are coloured the same as the gas bottles.
No!
there is no regulation or code of practice that defines the colour of Propane or Butane bottles or regulators Calor uses Red for Propane and Blue for Butane, but other suppliers can and do use different colours.
As for which gas "burns hotter" A propane flame at its hottest point in air is about 1930C compared to butane at 1900C, that is a 30C difference of about 1.5%
However from a users perspective that temperature difference is not even noticeablke as its other characteristics of burning LPG that will swamp that difference.
Effectively what you need to know is how long will it take to boil that kettle, and how much gas will be used.
There are a whole raft of factors that affect this result, but effectively for a delivery pressure of 30mB (the current EU standard for both Propane and Butane) Butane will deliver approximately 20% more heat energy per unit time into the kettle than Propane. So if all other factors are equal, a kettle on butane will heat up faster than on Propane.
But gas heating power is not the only detail factors involved, so in practice the effective differences are actually quite small and probably only about 10%. Where the appliance has a genuine variable gas throughput thermostatic control, such as Gas space heater, Oven and fridge, the thermostat will adjust the gas input rate relative to the required temperature and reduce the differences even more.
Purely based on the net calorific value of the gas per kg where propane is 46(MJ/kg) and butane is 45.6(MJ/kg), and as similar sized butane bottles tend to have a greater weight of gas than Propane, Butane bottles will last about 15% longer.
If you are caravanning in temperatures below about 4C you should be using Propane, If all you caravanning is above 4C then Butane will be fine.
