Pump not pumping !
Hi , I have a Bailey Wyoming 2007 with a whale inboard water pump.
We last used it over christmas and it did not get frozen or anything - but when i tried it yesterday it made all the right noises but did not pump the water !
It would not fill the heater and when i switched it over to fill the inboard tank nothing happened. It makes all the right noises.
Any ideas ?
Andy
A couple of thoughts:
A possibility is that air is getting in on the suction side; are you sure things did not freeze such as the residual water trapped in the inlet filter?[ assuming it has a pre-pump filter as these pumps ought]. If that froze it could crack the filter housing.
Also these pumps are susceptible to debris sticking open the discharge valves which stop them pumping.
