Hi Woodlandscamper.
Thanks for that advice.
Mine is the Purpleline eGo mover and i have removed the 3 allen key bolts which hold on the half shroud and end cover cap then i removed the spring sirclip which was around the central shaft, apparently from what a fitter and Purpleline have said is that it should now be free to come off its internal shaft however it wont as it seems jammed in position.
The fitter who puts these on advised to spray some WD40 or similar down the central shaft over 2 days and allow it to soak in then try and prize it off with a couple of screwdrivers but ensuring i don,t damage the actual casing, he said all of a sudden it will release and come off.
Does this sound correct.
Gilbo.
