Radio Fitting Ranger Series 5
HI,
Have any of you fitted a radio in the above. If so where did you place the speakers & how did you route the cables?
Thanks in advance
I wouldn't recommend fitting the speakers where Bailey tend to fit them, in the front corners under the top lockers facing downwards.
They are very difficult to hear if you are anywhere in the van other than sitting directly beneath them!
The speakers are mounted in the bottom of the corner lockers just above the front window, I think the cables run inside the lockers this seems to be the obvious way as the radio is in the locker near the door (Pageant Burgundy). My choice would be to mount them where the 240v corner lights are, at the front corners facing into the van.
