He-he! Knew you wouldn't be able to resist that one, Clive! Btw, As I think I've said before, I run a 4.2 LSE on LPG which for me, is just about the perfect towcar.However, just lately it has developed a problem that neither time nor money seems able to fix.It has suddenly started not starting, if you see what I mean! There is no pattern to it, it will be fine for weeks, then one day won't start.Place a fan heater under the bonnet for 30mins, and away we go, for another couple of weeks, then the same again.Between myself and two local LPG and LR independents, we've replaced all the ignition, plus all the temperature sensors, but I still have the problem.When it does go, there is no sign of a problem,but the garages cannot fix the fault if the fault isn't there when I take it to them. And yes, they've been out to it too. Any thoughts, or should I just set fire to it?
