hi ive got a rear leg bush gone are these easy to get old of and replace or is it a hard job been under the van at the weekend the bush has gone on the underside were the thread goes but thread fine thanks lee
Have a look on here & see if its the same as yours.
Just had a look at mine & the only problem that i can see would be punching out the roll pin that goes through the bar just behind the nut that you wind.....
It might be easier to remove the steady to do this.....
