Rear View Camera
Page 7 - Passionate about caravans & motorhome? Join our community to share that passion with a global audience!
colin-yorkshire said:
Wow KEV, thats a good installation, and there was I thinking you were no good with electrics
, very proffesional. well done.
if mine worked half as well I would be a happy bunny. although I have gone for the simpler (temporary) option and I don't think my kit is a good , but it was cheap so you get what you pay for,
glare is the biggest problem matte pads dont help much I think it is the design of the viewer being a mirror thats the problem as the cameras work fine, but it is discreet and fully automatic, any view from the back of the van is better than none, and I can now see the small trailer "just" when towed, no pictures i'm afraid as the photobucket account is locked,for some reason so it is hard to explain what's wrong, will just have to keep experimenting for a solution,
I wasnt Until you and Sprocket came along Colin!!!
Colin could you change the mirror veiwer to a monitor like ours in the photo's
Have you contacted photobucket to get you back in, I had to once, took them 48 hours to reply but I got back in.
Colin as said previous Sprocket has a lot to do with this and deserves's the praise
the majority of it was Spockets ideas (clever ******) and with his step by step guide it was quite easy for me with a small amount of tweaking..
Think he should start a seperate thread on How to install a Rearveiw Camera and then Parksy could make it a Sticky
How about it Sprocket?
Hi Kev, I will try and make this short, first I agree about Sprocket he is very clever,
and his approach is very proffesional, a proper guide would be very helpfull to all, while some of his ideas are very close to mine I do tend to take the "Heath Robinson" route, and treat such projects as an experiment rather than a prototype full working model.
Rearview is one such project, instead of the full on perminant conversion of the van, using the best kit, couplers, and viewers, I first started by assesing what I wanted it to do, without modifying anything that would be a perminant fixture, with this in mind, I looked for a kit that could be fitted and removed if needed and would be descreet yet functional, my main concern was practicallity, I stood at the back of the van with the drill in one hand and a camera in the other and thought!!! NO I am not going to do this!!, not just to see whats behind the van.
in the end I came up with the idea of mounting the camera (different type) on a bracket that could be slotted over the rear window btm with the power fed from the vans 12v TV socket and a RCA cable through the van and out of the front window into the boot of the car,
the connection in the boot is via a splitter that also serves the tailgate internal mounted camera that can be used for reversing and seeing the small trailer (when attached), I went for the mirror mounted monitor as it just clips onto the normal mirror and all the wires are hidden in the roof lining and behind the interior lights, a switch turns off the tailgate camera, when the van's camera is connected.
everything works as it should do, and there is no problem with the installation, the issue is with glare from light pollution at night, and reflection in the monitor during the day, I could change the monitor to a screen type, and in the end may have to, but this would mean re-routing the wires, and unplugging it every time I left the car and plugging it back in when I used the car. seems a lot of hassle to me not to mention the wear on the RCA connectors, one solution would be to use a radio mounded head unit with screen, (as suggested by Watson John G) but this would be a big investment "for an experiment".
I will get round to posting some photos once I have sorted photobucket out " it seems to have forgotton my log in, (or I have)
in the meantime i still have a few ideas left,
and ps, sorry it wasn't that short.
colin.
I have just been driving a car which had a rear view camera which activated when in reverse.
Not bad the only advantage I found was the length of the car... have to say it was left drive and large a hyundi of some sort.
but it would have helped with hitching up on my own instead of having help from my "I've no idea what to do daughter"
I was impressed with the size of screen in the car with it sa nav, much better than ours, it operated everything all aircon.. and told the outside temp too!
Don't know about english with cameras though so can't help there...
I will have to contend with my own eyes for now...
good luck
Hi Sir Gagakev WC (2 Bar)
Well after driving home in very heavy rain today from the Woosifest, I am pleased to say that i was still able to see what was right up my AR53 on the M1 even though it looked a little foggy due to the heavy spray that came & went just as the rain did, all in all it's the best gadget that i have fitted to the van........
glad it is still of use Sir Sproket, mine stopped working after 25miles from leaving home and not worked since could be a fuse or a connector, I suppose but will have to strip the boot out to check (installation error) but i'm not doing that in this weather.
Hi Sir Sprocket
Plugged in at Kingsbury this morning and couldnt see the trees behind me
So went and had a look and it was covered in dew/mist, cleaned off and hey presto perfect veiw.
Agree with the foggy picture due to the spray but as with you could still see
Stopped at Gordano Services, another wipe and clear the rest of the way home.
Wouldnt be without it now.
Considering you both need a big step ladder to reach the cameras I am surprised the spray got that high!
I wonder if there is some diffuser you could fit. A bit like the steam deflectors fitted to some of the steam engines of old?
These two cameras are to die for. I'll have a bash on the spring
Considering the amount of heavy rain that we both drove through on separate journeys, i don't think that a deflector would really help, as the passing air can pass close to either of the camera lenses & I think that it helps to keep it reasonably clear, rather than allowing the rain to turn to water globules & making it harder to see through if a defector was fitted ( think what the rear window of your car is like when it rains )
When the cloud bursts stopped the camera lenses became clear by themselves.
But I suppose we could fit one of these
I have never needed to clean mine on route due to rain. Its mounted on roof level but overhanging around 4".
My only problem is when its sunny, cameras don't like sun.
