I have often wondered about the practicalities of having the fridge vents in the awning, particularly on very hot days when the tempriture in the awning can rise drastically, Our van a Coachman Amara has its fridge venting into the awning.
I wonder myself whether it would be worth manufacturing some flexible ducting to clip over the fridge vents (the stuff I am thinking about is the 4 inch flexible tubing often used for extractor fan vents) this could be ducted out down from both the upper and lower fridge vents and down out under the caravan, by putting a fan such as an in line extractor fan on the end of the upper vent duct the warmer air from the top vent could be pulled out under the caravan which would then draw cooler air also from under the caravan into the bottmo fridge vent duct, this would sureley have the effect of helping fridges strugging in hot weather.
Obviously there in no way this method could be used with the fridge running on anything other that electric (due to the fridge flue being behind the top vent) but as we always run on electric I am sure it would help.
Any comments ?
Regards
Mark
