Reich Caravan Mover
Hi there, I may have the possibility of a used condition Reich motor mover a 2003 model of which i would want to fit to my 2002 Swift Challenger single axle, any comments or advice would be appreciated, good or bad on these models, also as to how they fit would also be appreciated.
I can't afford a new model so if this is no good what other movers may be worth looking out for in used condition.
Many Thanks
Andrew
I have a reich mover which is now on its third caravan a bailey imperial, an avondale dart 550 and now on a bailey ser.6 monarch no problems so far if it slips just tighten it a bit more
I also have the full manual and fitting instructions if you should need them {borrow}just get back to me.
Will {Scotland}
am happy with ours nearly 5 years old,am thinking of the aluminium rollers instead of gritted ones if anyone knows what the cost is and where to get them?
Andrew,
I have the same model, it is a clamp fit to the chassi (no drilling required) I drilled four seperate holes thro the caravan floor to get the cables thro and then sealed them,
BE CARFUL WITH POLARITY I GOT IT WRONG AND BLEW THE CONTROL BOX.
GOOD LUCK MATE
Tony A.
Thanx everyone so far for your comments. they do sound good! I must admit I know nothing about them.
Another question what would the max you would pay for one of these items, bearing in mind this one is in use condition and a 2003 model.
Its at a local auction coming soon and I need to know what should the max be i bid upto.
Thanks again
Andrew,
On E`bay at this time there is one with 8 bids at two hundred pounds +35 postage with 2.5 days left on the auction.
they are about 800 pounds new, it all depends how many people are at the auction who want a mover.
Let us know how you get on
Good Luck Mate
Tony A.
