Reich motor mover
Aug 14, 2006
87
Hi i am looking for advice on what to check on my mover, it works only the l/hand wheel when looking at the van from the towbar. I can hear a click when i try to drive the r/hand motor but no movement i just fitted a brand new battery last autumn.
937
Assuming the battery is fully charged, check the connections to the motor on the affected side.
Next is to go to the control box and measure the voltage going to the motor, at the connection terminals.
If you have full voltage at the terminals, then the problem is at the motor end.
Feb 15, 2009
300
Caslau have you tried the remote with the wire feed from the remote to the control box it might be that the remote is faulty . do you have the remote actuater to the wheel or do you have the manual one . have you tried it with the rollers off the wheel just to see what happens .have you checked all the wiring conections are tight
cheers Duggie
