Reich mover
my reich mover is only operating on one side, the other side revolves but when brought into contact with the tyre it stops. does anyone know what the problem may be, is there a clutch or drive plate/worm that may be worn. any advice welcome, thanks.
provided the unit has been fitted correctly, from your description it point to a voltage problem. as soon as the motor is engaged it will require more amps to move than when it is away from the tyre. the battery needs to be at least 90amp and in good condition. i would have your battery checked first and make sure the battery terminals are clean and connected to the battery correctly. if the problem still persists contact a dealer who fits them.
