• Weโ€™re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. Weโ€™ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Remitop rooflight string snapped
In case anyone has a similar problem we got 'brave' in the end and found the screws connecting the whole unit to the roof (covered by plastic covers). We could then look into the unit and managed to re-tie the string back onto the screw that it had come off - job done!!
Jan
Previous similar topic
Hi, I have the same problem with a RemiTop in a Bailey Pagent Bordeaux 2000 (which I assume is similar to yours given the description).. Did you have to completely remove the unit from the roof or did you find a way to replace the string from inside? I've removed the plastic covers which revealed flat metal plates but I fear removing those will lead to the whole right coming out which is rather not do unless I've no choice.
Thanks in advance!
Hi Sticks, welcome to the forum.
I've moved your thread to create a new topic.
Forum best practice is to create a new thread when one that you're joining is over 3 months old.
This is because a fresh thread is likely to attract more replies.
I added a link from the previous topic to your comment.
Thank you ๐Ÿ™‚
