Removing a sticker from window
2,064
There was clearly some sort of sticker on the inside of the front window of our new to us Elddis. the sticker has gone but gluey remnants remain. A hot cloth has succeeded in shifting the glue a bit but it is slow going.
I don’t want to use abrasives as it is so easy to scratch plastic windows
Has anyone used Stick Stuff Remover on a caravan window. Is it OK?
Any other suggestions?
Thanks in advance
2,494
Thanks in advance
I have used it many times over many years with no I’ll effects, but I would try a trial area first, perhaps on an normally unseen area with the window open.
Reactions: Mel
2,064
Thank you all. I don’t own hairspray so will give sticky stuff remover a careful trial. Have some at home so job will have to wait for the next outing.
2,494
Not only do I not have hair spray. I don’t have hair!
4,983
Sticky stuff Remover only.
Mel do not use WD40, or nail varnish remover or anything with petrochemicals. They will react with poly plastic causing damage.
Be gentle. Too much cleaning may make it worse. Maybe you need a new Woosie sticker😜😜
Reactions: Mel
