Replacing a window stay pinch Lock
Status
Not open for further replies.
Apr 26, 2005
208
The pinch lock on the window stay of the centre front window on our 2011 Lunar Clubman will no longer tighten and probably needs replacing. Unfortunately I can see no way of removing the window stay from the window (the opposite end unscrews from the window frame).
Does anyone know of a way to remove the pinch lock, without removing the stay. There is a hole in the pinch lock with a small metal 'tube' inside that secures it but I cannot work out how to remove this 'tube'.
Any ideas gratefully received.
Regards,
Ron. W.
937
On the window catch end of the stay you will find a very smal hole, insert a 2mm drill bit or very small screwdriver to release the lock, slide the catch off the window.
Jun 8, 2025
A lot of years later and that advice is still gratefully received. Had no idea how to get the catch off. Many Thanks.
2,293
Thanks for the feedback. Glad it was useful. I have, however, locked the thread so as to prevent further discussion on such an old thread.
Status
