Replacing Halogen Downlighters with LED
Feb 2, 2024
161
28
585
Hi i am trying to do the above but having crimped the cables up and connected them they don`t work do i need a conversion/transformer box or something any advice would be appreciated.I have a Bailey Ranger 520/4 gt60 2010.
4,638
LED's will not illuminate unless connected the correct way round. Test the actual led on a battery, to make sure it works, then crimp the correct way round.
Feb 2, 2024
161
28
585
ive tried swapping the connections out but still no joy,i will test them on a battery see what happens theres a black and a red wire on the LED
Feb 2, 2024
161
28
585
these......
Dream Lighting 12v LED Downlights With Chrome Plated Surround, Recessed Ceiling Lights For Caravan Motorhome Van Boat Yacht Warm White Pack of 2 [Energy Class E]​
Jan 19, 2002
1,708
550
? Blown fuse on distribution unit or the main fuse between battery and distribution unit ?
Oct 19, 2023
629
504
2,135
LEDs generally operate between 1.2 and 3.6 volts. The units you have bought will have a built in DC-DC converter to drop the voltage from 12v to the voltage required by the LED. It's possible that these may have been damaged if you connected them reverse polarity, is there anything in the instructions to say whether they have reverse polarity protection?
It's also possible that they were faulty when you bought them, how many did you buy?
You could hook up one of the old lights to prove the supply is still there, if it is it would seem that the LEDs are dead.
2,707
Two tests,
Do you have voltage at the connecting wires?
Do the new LED bulbs work when wired directly to a battery?
