Replacing lock
Apr 24, 2021
13
15
One of my locks is broken and I am unable to get the key in. It is one of these Does anyone have any suggestions on how to remove the lock please. TIA
5,395
Is the broken lock in situ in the locked position? Key not broken?
Squirt a liberal amount of WD40 or similar into the lock. Leave for 30 minutes and try again. If all else fails you will have to drill out the lock and replace it.
Apr 24, 2021
13
15
It is in the locked position with the door closed. The key will only go in part way and seems to be hitting something 'solid'. I have tried wd40 but to no avail as I say something seems to be stopping the key going fully in.
Jul 30, 2007
1,461
404
19,435
Don't suppose it may help to insert a very,very fine screwdriver to try and move the obstruction out of the way to enable you to get the key in.?
4,047
1,782
I stripped one out once in a Hymer from the inside outwards.
I recall the lock tumbler was housed in a die cast cylinder with flat extended shaft, anyway ours all came apart.
In your case you are going to need some bits or a new assembly, but removal is "doable" and all very easily.
Edit: there are some hints in this You Tube or the other several ones out there.
With the tumbler assembly out, key out, you ought to be able to push in the little securing plate and remove the lock's inner core. These cores can be ordered against key numbers and I recall were very cheap to replace.
Even easier if you don't need to order a special one to retain key commonality, as one dealer had them as an on shelf item.
13
15
Thanks you say removal it easy. Can you please let me know how TIA Won't I need to get it open first?
4,047
1,782
I did not pick up anywhere you said that it was also on some closed locker, just you had a key insertion issue.
Thus follow the advice to drill or otherwise disable it and replace all that is needed.
These things are anything but "secure".
Apr 24, 2021
13
15
5,395
This should give you a good idea. Take your time . May I suggest you source a new lock before hand so you can do the whole job in one go.
Apr 24, 2021
13
15
Thanks for your help
Oct 3, 2013
890
90
18,935
Hi,
Caravans are dead easy to break into.You don't need to go in by the door.If you get into the van try by unlocking and opening the door from the inside.
Mar 27, 2011
1,332
507
19,435
Hi speckled hen, there’s a lock exactly the same on eBay, brand new 11.99 so cheap as chips and I’m sure the new one would enable you to see how it goes together, just go on eBay put in caravan door lock and it was about the 3rd item down
Reactions: Jcloughie
Apr 24, 2021
13
15
Brilliant thanks
