VicMallows said:
.... Too many people are afraid to tackle the simplest tasks these days .... especially if 'gas' is involved.....
I'm sorry VIc but I have to vehemently disagree.
Having been involved for many years with the gas side of caravans, I have seen some quite dreadful DIY jobs which were positively dangerous, and in 4 cases did cause serious injury to people. Its just the grace of God none were actually killed.These were jobs carried out by rank amateurs who failed to read instructions yet alone apply the correct test methods.
Then there were those jobs which on the face of it looked OK, but under closer scrutiny things had not been done quite correctly, still rendering the installation unsafe, for example compression couplings over tightened so much that the olive was beginning to cut through the soft copper lines.or over stress the point where the pipe entered the coupling " Oh I've tightened them every year just to make sure they're tight"
Then there are those who simply didn't put the olive in and relied on "boss white" or "super glue" to seal the pipe, but of course LPG dissolved it.
Flue pipes not connected, and industrial regulators fitted becasue the standard one didn't get the oven or grill hot enough! Even one who had cobbled up a connector to a Camping gas bottle with no regulator at all!
I know in the grand scheme of things these are very small numbers BUT there are proper and reasonable tests that needed to ensure gas products and installations are safe, and the vast majority caravanner neither have the experience nor the equipment to carry them out.
If not for your self, think of those near and dear to you, or your neighbours. and of course the poor person who buys your caravan after you have finished with it.
There are good reasons that so many tests are required on gas systems, and just like so many caravan related issues it seem some people think its fine to cut corners.
Contrary to what might appear from this post I'm not against all DIY, just those people who support dangerous if not illegal practices.
