RM5330 Fridge
Can anyone confirm that the fixing points on the RM5330 fridge, screw through the internal sides of the inner case. The view on the Dometic website photo is so small it's difficult to see, even when enlarging it.
Yes they do .
You will see quite clearly 4 cover caps , 2 on each side.
Ensure you don't use too long a screw to go right through the furniture carcass you are securing to, and use stainless steel dome head screws.
Cheers Damian, I'll have to order some screws, i don't stock any stainless steel stuff. I would think 4mm X 20mm should suffice, that's what came out of the old fridge !.
