Roll Safe Towing attachment
Apr 1, 2007
Hi all,
I've just gotten, from a friend, a Roll Safe anti snaking device.
All the component parts are there (I hope!!) but there's no set-up instructions (he's 74 and has mislaid them, bless him..)
Has anyone used this and can remember the set-up instructions or has a set-up guide?
Any help would be GREATLY appreciated.
Regards,
Barry.
Nov 1, 2005
1,001
Barry, when you say rollsafe do you mean the trapezium type? If so are you aware that it is illegal to fit a trapezium stabiliser to any vehicle registered after R reg?
Aug 4, 2005
1,204
14
19,185
Barry,
I used the Roll Safe made by Trapezium for several years up until last year when I changed my caravan to one which had an alko stabiliser. I reckoned it was an excellent stabiliser, far better than the Scott which I had previously used.
I don't know if you are aware or not but this piece of equipment falls foul of the EEC regulations regarding tow balls and brackets. Because the towball is part of the stabiliser and moves to and fro as you are driving it does not meet the requirement to be a specific minimum distance from the tow bracket. This supposed non compliance was one of the main reasons why the company stopped producing them. I must admit continuing to use mine until I changed my van but it was always in my mind that if stopped at a vehicle check point or involved in an accident I may have had problems.
Anyway if you still want to fit it I am happy to try and help with instructions, from what I can remember it was not too difficult. Explaining how to do it in writing might not be so easy!
There are four pieces to the stabiliser ( I'm assuming it was the detachable version) - 1)a bracket that fits to the towbar in place of the tow ball 2) the main stabiliser part which has the tow ball and slides over the previously mentioned bracket 3) the stabiliser arm, roughly L shaped and made out of round metal bar, approx 2/3 foot long 4) small L shaped bracket which clamps onto A frame plus bolts.
Fitting instructions to the best of my memory were:
fit bracket to car tow bracket in place of tow ball- held in place with two bolts, attach main stabiliser unit to bracket- just slips over the top, hitch van up ( sorry should have said this to be done on level road with van & car in straight line), place short end of stabiliser arm into bracket ( this has to be done with long end of bracket pointing straight up, then when fully pushed home turn it down towards the van,because of the way the end of the arm is shaped it then can not come out of the bracket). You are then ready to mark location of the small L shaped bracket. This is fitted very similar to the brackets which hold the spring type stabilisers. Try and keep the arm of the stabiliser as horizontal as possible and have it so as the end is approx 8 inches overhang on the small L bracket, you want it so that if you make a sharp turn to the opposite side from which the stabiliser is fitted to it will not come out of the L bracket housing. Once you have decided on the bracket's position clamp it in place.
Important - please ensure the arm is fully locked in place before driving and never tow without it, very unstable.
It is easier to do than explain. Any questions please ask. Somewhere I may still have the instructions, if I can find them I will let you know.
Robert
Rob,How do you compare the performance of the Trapezium with the Alko friction hitch?
I used the Trapezium for a few years and was sad to see it outlawed but I have to admit that the Alko is very convenient to use and has surprised me that it works so well .
Aug 4, 2005
1,204
14
19,185
JohnG,
I was very happy with the Roll Safe and continued to use it after it was deemed inappropriate by the EEC regulations. The only down side to it was the very slight inconvenience of having to fit and unfit the bracket and find storage for it when not in use.
I had used a Scott stabiliser prior to the Trapezium and while having no complaints about the Scott found the Roll Safe to be much superior. As I said in earlier post I only stopped using the Roll Safe because new van had the Alko stabiliser as standard
so I could not give a direct comparison of different stabiliser but same van. Having said that I have found absolutely no problems with the Alko, main holiday last year was from Central Scotland to North Spain via Hull-Zeebrugge and van felt very stable at all times. As you mentioned the Alko is also convenient, no need to take attachment on and off. I think I noticed the big difference with the Trapezium when I first bought it as tow car at that time was a Laguna estate, since changed to a Freelander which makes a better towcar anyway.
Robert
Apr 1, 2007
Hi all,
Just wanted to say thanks for all the info. I decided against using the device. Don't want to get stopped & copped!!
Will go for an Alko when funds alllow.
Thanks again,
Barry.
Aug 4, 2005
1,204
14
19,185
Barry,
I think that it is probably the wise decision. It was always at the back of my mind that if I had been involved in an accident and insurance company discovered I was using non approved type towing equipment they would use that as an excuse not to pay out immaterial of cause of accident. It was also a possibility that you could be stopped by a policeman with some knowledge of towbar regulations. Pity as it was a good device.
Robert
Apr 26, 2007
10
hi I have fitting instructions for trapezium stabilizer
Ihave one fitted to volvo 850 est (1995)best thing since sliced bread
