Roof light blew off 🙈 please help
Hi there, does anyone happen to know the small rooflight dimensions in a Swift Conqueror 640 caravan, please? It has blown off in the recent high winds. I’m not there to check sizes but are all rooflights standard sizes? Seems to be 400 x 400 for the small ones but not sure. It’s the one outside the bathroom. Thanks
Why don"t you try a Swift dealer he should know what size you need good luck
Unfortunately they are not all the same size but there are probably several models with any size fitted. If you can identify the make and model you can shop around but otherwise a Swift dealer should be the safest route, although if you have an older model breakers might have a used one.
