sat nav tom tom 910
Feb 22, 2007
19
please can any one tell me if the 910 has a hgv or towing program as when we are towing the timing is way out thanks
Feb 4, 2007
293
Sorry Nigel the Tomtom 910 does not have anything like that. Having said that we find the timing is almost spot on unless there are roadworks or other delays.
Colin.
Mar 2, 2006
279
Hi Nigel
I have the tom tom 700 I think you have to set the max speed in your preferences,
May 31, 2007
104
Choose the 'Limited Speed' option, and set it to about 55mph, almost spot an every time.
NOTE, you may need to enable the option where it asks you what type of route you want (Fastest, Shortest, Limited Speed, etc)
4,405
Hello Nigel,
I make the assumption that you are asking about these features of Sat-Nav's to ascertain their ability to keep you to suitable roads for towing.
Sadly I am not aware of any Sat-Nav system available at the moment that uses the different vehicle settings (i.e. Car, HGV, Bike, etc) to select roads that are suitable for the type of transport chosen.
Most systems simply use the selection to adjust journey times. That is why we continue to hear of coaches and HGV's stuck in narrow lanes.
The systems do usually use the shortest/fastest settings to make adjustments to the route, but it still does not take into how suitable the route is for the type of vehicle chosen. It is generally the case that if you choose the fastest option, it will tend to keep you to major roads rather than side or minor roads.
Feb 11, 2007
575
We have the TOM TOM 700 and it always shows the correct timing what ever you set it on .It automaticly resets the time when hold ups happen.
