Michael. for cheapness and ease its got to be the Maplins in a case satellite system.
It does depend on your needs as regards TV viewing of course,probably the best in the UK but abroad others will advise you.
All in all a good
I too use one of the "suitcase" types from Maplin and have never had a problem setting up. Like Legsmaniac, I get a signal within 60 seconds and agree with him ............. it REALLY is not that hard.In the 20 times we've been away in the caravan in the year since we bought it, I've never failed to get a signal. I can now set up the dish in under 60 seconds every single time. It's really not that hard.
All in all a good
I use freeview, satellite and analogue depending on what i can get. Firstly do you always use mains electric? If yes the advice oin this thread is good. If not then you need a Maxview satellite box, the only one that is 12 volt. Point the dish at astra 28 degrees and you gettune in rem about 200 channels including all the bbc and itv, also channel 4. All free. I haven't found a 12 volt freeview box yet so use a mains one from Aldi(
