Satellite system
Apr 30, 2012
20
I am looking to start using a satelite system for the TV in our caravan due to the poor television signal in some digital areas. I have an old sky box which I wish to use, but I am unsure about wether i can use it and which other equipment I require and which is the best to purchase. I am not looking to spend a fortune on this and any advice would be gratefully appreciated.
Mar 3, 2012
31
there you go quality advice...what more do you need?
Jun 17, 2011
826
27
A couple of things- size matters. Remember that you need to be able to see the satelite. This means no trees or buildings between you and the satelie. I have found that a 66cm dish gets a picture when smaller ones don't. (Through trees or where there are montains.) I think Maplins sell a dish that has a g clamp fixing.
Aug 17, 2008
236
I use a rotary clothes line! Remove the line itself and turn it upside down. Works a treat with a standard Sky dish and cost me about a tenner. I have a small piece which unscrews from the bottom, now the top and I clamp the dish to this bit.
5,446
I bought this piece of kit 9 years ago. Amazingly the price hasn't changed much.
http://www.maxview.co.uk/products/info_B2566_KIT.html
Like Waffler I find the 66 cm dish easy to use.
My FIL did have an Aldi kit that for whatever reason was never very satisfactory and very difficult to set up.
I never use the sat finder, waste of space imo. SWMBO watches the screen and shouts out when we hit the correct transponder signal.
I now have a quad LNB and we take our sky+ box away. Never let us down yet. BTW move trhe dish very very slowly pausing frequently. A satellite signal is not like a TV signal and takes longer to lock on. Watch the angle of elevation too.
On mine Cornwall is about 26 dges whilst the Highlamds of Scotland are near zero degs!
Dec 6, 2007
414
Hi.
I went through various set ups before settling down with a domestic dish & a Tripod.
It works nicely & with the dish mounting modified with a screw adjustment & spirit level for eleivation its easy to adjust, I set up so i can see the TV through a window & level the dish for elevation then walk it into the signal from the east.
No problems ;-}
