- Nov 11, 2009
- 25,518
- 9,334
- 50,935
When we took the van out for its maiden voyage I thought that the Thetford seemed to get through flush water rather quickly. So did check to see if there were any leaks but found nothing. Then yesterday I was on the drive and heard a noise which turned out to be the flush pump running, even though the caravan power supplies were all switched off. But thats another investigation. So it looks as if the electric flush may have switched itself on at random times. I checked the press panel on top of the flush tank and the pump came on, but didn't immediately turn off without being pressed again. So it looks as if I have a sticky switch. Any tips on how to access and replace the switch? The toilet model; is Thetford 260.
