Setting up the awning?
Jul 13, 2010
125
I am abit panickaty when I do things and setting up the awning is no exception.
I have used the stiching as a guide and worked from there. The manual is about as useful as a chocolate fireguard. If I use the bottom stiching as the floor guide then the rubberband to peg is too loose.
Should the floor stiching be therefore above the floor?
To be honest I have looked around sites to see how other awnings have been put up but it was no help.
Kel
5,558
Hi Kelvin
What make / model?
You will see there is a plastic skirt sewn into the bottom of the awning fabric. If you were to rasise the poles so that 50% of the skirt was off the ground will that give you sufficient tension in the rubberband to peg?
Sometimes it is a bit of hit and miss. Awnings like the Isabella use a system whereby you have three choices of height.
Obviously no terrain is the same , hence the need for some adjustments.
Good luck.
Cheers
Dustydog
Jul 13, 2010
125
Hi DD
Its a NR Sterling 16' with or without end bedroom
The skirt is cut at the corners and with no way of fixing the skirt to the floor leaves holes?
5,558
kelvin
have a look at some of the NR Sterling pics on the net. Plenty there. Does that help?
Have you spoken to NR and explained your problem?
Cheers
Dustydog
Jul 13, 2010
125
I have looked at some pics and they show the bottom stiching higher than the floor level. This can be acheaeved by increasing the pole hights - but the down sides are holes in the corners were the skirt is cut and the inner bedroom 'ties' to the top poles are too short - so the bottom of the inner bedroom is just off the floor putting stress on the cross poles when slep in.
I can see easy ways of getting round this eg. fix pleated skirts to the corners and longer ties for the inner bedroom. but I was interested to see how others had got around this.
I am not 100% sure the age of this awning but it had never been used before me. The 'file' of paperwork I had when I bought the van suggests 1997. They do not make this awning now.
