Sevylor pump
Today I bought the Sevylor pump for our Sunncamp awning, I appreciate that this only inflates to 5psi so I tried the pump at that psi and experienced no problems with the low pressure hose this is almost identical to the hose which came with awning. So knowing that people with Kampa awnings are concerned about going to 11 psi I decided to try it on my inflatable dingy at the 15psi setting and again experienced no problems, So my conclusion would be if you have a Kampa you should be okay and if like the Sunncamp pipe work which is longer than the supplied you may be able to use that on this pump.
To any moderators, sorry but this should have been posted in the equipment and accessories, my computer crashed and I didn't recheck the destination.
