- Feb 2, 2024
- 167
- 29
- 585
Hi has anyone had the experience of replacing the front shelf in a Bailey Caravan? If so how difficult was the process? Regards
Apologies,bailey ranger 2010 520/4What year and model is it? Additional information would be helpful.
Thank you it was in my mind to do that so might get a thin upvc facia board.It can be done but not easy. Needs removal of chest of drawers, plastic edging , lower curtain rail. Then remove whatever fastenings you can see . Some may need cutting . Look inside the gas locker , you can see it and any other hidden fixings.
Frankly, I’d buy a new panel from Prima Leisure and simply over lay it with adhesive or hidden screws under the edging and curtain rail. Or make up your own panel.
Laminate flooring is fairly thin / light weight / hard wearing. Would give you lots of colour and pattern optionsThank you it was in my mind to do that so might get a thin upvc facia board.
Thanks again
