- May 27, 2014
- 219
- 1
- 10,585
Thinking about these for my abbey Iona vogue - worth it ?
http://i374.photobucket.com/albums/oo187/thosoneill/****/IMG_0342.jpg
Yes I have a powrtouch mover fitted - I'll check that out before I decide - many thanksProfJohnL said:Beware that some caravan movers can compromise the fitting of the dampers.
http://www.halfords.com/camping-lei...accessories/alko-shock-absorbers-green[/quoteAnseo said:Helpful post by Woodentop there .
First search brought up these, hope you find them at an even better price thosoneil.
]http://www.halfords.com/camping-leisure/caravan-motorhomes/caravan-accessories/alko-shock-absorbers-green
the caravan shop in great western rd in Glasgow have them all in stock at the same priceWoodentop said:Seems they only supply the green variety - could be a clearance?Anseo said:Helpful post by Woodentop there .First search brought up these, hope you find them at an even better price thosoneil.
thosoneill said:the caravan shop in great western rd in Glasgow have them all in stock at the same priceWoodentop said:Seems they only supply the green variety - could be a clearance?Anseo said:Helpful post by Woodentop there .First search brought up these, hope you find them at an even better price thosoneil.
ProfJohnL said:Hello Dusty,
I stand to be corrected, but it would be illogical to rate the dampers based on the trailers MIRO, It will almost certainly based on the MTPLM, becasue most items like this are likely to be damaged if you exceed their stated limits, which of course would always be the case as no practical caravan ever runs at its MIRO. This could be a major issue for things like horse boxes where the pay load represents a major proportion of the trailers MTPLM
In the case of caravans, the payload is most often lass than 25% of teh MTPLM so the difference is that great, but even so you should select dampers based on MTPLM.
The original brochure states ex works weight 728kg - maximum authorised weight 920kg and maximum technical permissible weight 950kg - I assume therefore that the green dampers will sufficeDustydog said:Back to the OPs original query. What is the MTPLM of your Iona?
thosoneill said:The original brochure states ex works weight 728kg - maximum authorised weight 920kg and maximum technical permissible weight 950kg - I assume therefore that the green dampers will sufficeDustydog said:Back to the OPs original query. What is the MTPLM of your Iona?
