SHOGUN 3.2 LWB Owners
Dec 23, 2006
788
Does anyone have a loud creaking noise from the brakes just before you finally stop.My shogun is an auto and when i half release the brake pedal in slow moving traffic so the shogun is moving without pressing the accelerator i get the same creaking noise. My dealer has fitted new pads and skimmed the discs.
Any ideas please?
Hamer.
Jul 5, 2006
146
Hi Hamer,
I've got a 3.2 Shogun and I do sometimes notice a groan from the front under the circumstances you described. I have put it down to the auto box still trying to drive the car forward. Unlike manual cars as one comes to a halt you dip the clutch and remove drive from the engine, with an auto box drive is always there albeit not fully due to auto slip. So what happens is as you reduce the pressure on the brake pedal the pads grip on the disc reduces and the vehicle starts to move forward,at this point the pads are still in a pressurised contact with the disc and a low resonance vibration is created. Brake squeal is basically the same phenomena only at a higher frequency due to higher disc rotation speed.
I also used to get the same noise from my automatic Omega and have experienced it in other auto cars when creepung forward while still applying a light brake.
It is nothing to worry about, just the discs moving through the pads while they are being pushed into the discs. My Shogun and most other cars do the same
My sons 306 does it if you "play" with brake pedal whilst creeping forward, as does my other sons MR2, our Freelander and Discovery.
My old Range Rover did it as well.
It is just "talking to you" - it wants to go "walkies" off tarmac!
