Shower Hose problem
Feb 3, 2008
31
Hi
Having a bit of a problem with a shower hose. When I bought the cravan the shower hose was hanging off at the tap end. Dealer said it looked as if someone has tried to steal so it would be fixed before we picked it up.
First time out, turned on the water pump and unbeknown to me the shower tap must have been turned on a little as the shower hose promptly 'blew off' the tap and water gushed out.
My question is......should the shower hose 'screw' onto the connector on the tap or does it just 'push' over an 'o'ring (as suggested by the dealer. He has had the caravan for a week and when I phoned yesterday to check the work he said he couldn't find any leaks or what the problem is, and that he'd had the shower running all day without problem. I can't see how it can suddenly be OK when the pressure of simply turing on the tap blew the hose off its fitting.
(The dealer has proved to be an utter £$%^&* to date and it will be the last time I go anywhere near him before issuing a solicitors letter for any refunds necessary from furtue work if he hasn't fixed it, at which point I will name and shame.
Thanks for help.
Andy
937
Andy, most normal shower hoses screw on to the tap fitting.
It may be a push fit, but very unlikely.
I do not quite follow the dealer when he says he has had it running all day? how? and would he waste so much water?
Sounds a little dubious to me.
Feb 3, 2008
31
Thanks Damian i thought that was probably the case. As for running it all day.....my sentiments entirely. I feel that the words I'll be having when I pick it up will be completely unrepeatable on the forum......as i said I've got to the stage where he hasn't got a leg to stand on and I intend to make his life as difficult as possible.
