Shower tray.... Is mine an odd size?
Jul 23, 2020
124
16
4,585
So the tray has been damaged (before I bought it) and I'm now changing it.
The measurements are 888x666x80 but I can't seem to find anything that big? Am I just not looking hard enough?
9,104
There are specialists who can visit and do an almost perfect repair on shower trays, sinks etc. Caravan Medic is one franchise. Others appear via a Google search. You can but DIY repair kits too.
Jul 23, 2020
124
16
4,585
IMG-20200903-WA0008.jpegNot sure this can be repaired, there are other cracks as well where the screws go. I'm having to sort the flooring as well as it was once wet so has rotted a little.
2,675
I think that trays are often made specifically for each van. But one of these universal trays may suit. Try to Google 'universal caravan shower tray' for more. They are oversized so they can be cut down. But I cant think how they edges could then be sealed.
This may help for fitting.
Reactions: McLosi
Jul 23, 2020
124
16
4,585
Thank you. I did find that one after posting and think that's the best I'll get.
1,819
If you are as Scottish as your name there is a firm called Anderson at Livingston who can repair them. There are others around if you try Google.
I think you will find that the tray is specific to your caravan model and they are just moulded to fit whatever space the designer has left for the shower. Caravan dismantlers might have one if you check, but it often means taking out the whole shower unit and can be a very long job.
Jul 23, 2020
124
16
4,585
haha sadly no, Southern softy!
I have the tray out and assumed they were sort of an easy thing to replace, but now seems not so. I may look at getting some fibre glass and repair myself, or get the big universal one.
2,580
you might be lucky there some caravan shower trays on Ebay
if not try caravan- breakers
Jul 23, 2020
124
16
4,585
Went to get the universal one but our of stock until Oct, going to try and repair my old one unil I can get the universal one or a replacement. Will try the breakers as well.
1,819
You might try to google for a repairer in your area, or check with any workshops that might be able to do it or recommend someone suitable.
