Oct 14, 2006
Hi,silly question have you removed shower head and
checked for limescale build up?
Might be blocked by foriegn bodies of muck buildup in pipes. Cheers Heidis hubby.
Oct 17, 2006
1,489
To Heidi, I have tried that already, I will try Ewan's suggestion. Liz
354
Had a simmilair problem on our Lexon. I changed the shower head and the shower hose, this solved the problem.
40
If it's not the hose to the shower head, then it's probably either the pump or the pipes supplying the shower mixer.
If you get plenty of water from the sink and or basin taps, then the pump is probably OK, so trace the supply hoses back from the shower. The most likely casuse will be kinks in on or both hoses, probably where they change direction, e.g. go round a corner. I've seen a whole number of vans with this problem which should have been found and sorted during the PDI, but that's another story.
Oct 17, 2006
1,489
To Ray S, Thanks for your advice, Water from taps are fine, so must be kink in tubing. I am putting van on pitch again at weekend I will have a look for kinks. Thanks.
Oct 17, 2006
1,489
Thanks to all who have helped me with my shower. I am putting van on pitch again this weekend, so I will try all your suggestions, hopefully I will rectify the problem. Liz
