Hi To all you Techies out there . Sir Roger is still trouble with this pump. Earlier on the year my Flo Jet pump died .I went to our dealership who could only supply me with a Shurflo . Now this pump has been a complete nightmare .After fitting it we primed as per Swifts handbook and at closing the taps the we get a horrendous knocking that goes all through the van . We put up with it for our first tbreak this year then back to storage and prime it again where we didnt have one splutter from the taps just this knocking when the taps turned off . I thought I will accept that but when went away a week ago the knocking from the pump appeared to be when you open the as well as closing it . It was suggested I fit a none return valve to the pump which did help on the cold side ,little or no difference on the hot so I have now put anther non return to the other side of the pump which has stopped the banging when you open the tap but still there on closing the taps . I niw have another problem that I cant Identify within the van and that is an anti surge valve in the rear of the van . What does it do ?I am ready with the matches and lighter fuel ready to set fire to it . Oh also went to dealers today and passed this problem to one of there bods who suggested it maybe something on the water heater that has a cleanable, replaceable valve I cannot locate this without undoing things Im not sure of. All this just by changing a pump so please I hope somebody has the answer.
Sir Roger
Sir Roger
