single induction hob
Oct 16, 2022
29
7
1,535
hi all thank you for the previose advice throughout the summer we have realy enjoyed our first adventures in the caravan was rather a steep learning curve but navigagated through it with you help an others we met on the campsite i am looking for some advice again we bought a single induction hob for us in the caravan but now my wife would like to use it outdoors when we are BBQ ing now i know you shouldn't split the mains electric going in to the caravan so how would I set it up would I run an extention lead from the caravan or something else already learnt about over loading the system and tripping it out
May 15, 2023
137
118
135
Firstly, what's the wattage of the induction hob? the ones I have seen are 2KW , there may be ones that consume less power.....assuming it is 2kw, its going to draw over 8A, so that rules out using it on any sites where the supply is only 6A.
Assuming you have a site where the electricity supply is adequate, then any extension lead that is rated 10A or more will do the job, if the extension is on a reel remember to unwind the reel completely .
Reactions: ProfJohnL
Oct 16, 2022
29
7
1,535
Thanks very much
Fit an external 230v socket!
how is this don
Oct 16, 2022
29
7
1,535
the hob goes from 300w to 2000w
Feb 12, 2022
11
7
4,515
I have 2 vango sizzles which I use alongside my electric hotplate outside from an extension lead ran from the van. I don't like cooking inside unless the weather says otherwise! Never had a problem
May 15, 2023
137
118
135
Don’t forget that even on a “low” setting the induction hob will draw a higher current until it is up to temp, probably the first 20 seconds, but as long as the site has a 10A or higher hook up, you will be fine.
3,924
Just an aside, In case you didn't know that Induction Hobs can interfere with operation of some heart pacemakers. If you or anyone nearby has a pacemaker they shouldn't get closer than a meter and certainly should not operate it.
Nov 30, 2022
1,708
1,552
2,935
As you are unaware of how to fit an external 230v socket then you need to get a caravan dealer workshop, or AWS engineer to do it.
Think in terms of about £150-£175 to get the job done.
2,941
Microwaves can also cause issues with some pacemakers - advice is not to go within 60 cm.
May 15, 2023
137
118
135
I'll stick with our outdoor gas BBQ where I am in control of the fuel supply and it has real flames! (I'm not a pyromaniac honest!)
The site were on in France last month only had a 6A hook-up, an induction hob would (should) have tripped the site supply breaker.
