Site water fed into Water Barrel or directly into Caravan?
3,829
1,555
Our caravan flooded using an aquaroll and there was nothing anyone could have done about it due to it being a pipe issue in the caravan. I never mentioned using the adaptor, but if a pipe fails, adaptor or not the caravan will still flood as the pump will activate as it senses loss of pressure as if a tap is open.
But the missing fact , is with a direct connection supply, the risk of a pipe failing is very significantly increased. This is simply because it could be subjected to pressure above the maximum limit of the system, something the submersible caravan pump can't do.
Oct 19, 2023
550
435
1,135
My query is... given the trend appears to still be AR and Valve setup over Direct Feed one, has anyone seen a compact external tank so that you don't need the AR and can use something like a compact 10 litre container, that already has a valve controlled water inlet (with suitable hoselock type connector) which then offers a top entry for your water draw-off pipe?
Mel mentioned the solution to your problem early in this thread.......... not cheap though.
Reactions: JTQ and otherclive
2,989
True.
But the difference is the aquaroll scenario does not apply a constant mains pressure to the pipes whereas the direct link does.
Agreed if the unpressured pipe breaks the pump will trigger and flood.But the chances of a low pressure pipe failing compared to mains high pressure are vastly different.
Just how many after-market direct systems use full mains pressure - rather than using a pressure regulator? All the ones I've seen include the regulator, in which case your warning is irrelevant.
Feb 13, 2024
912
570
1,135
look on the bright side, it was just a aquaroll full of water, if it was direct feed it would have been worse.
Reactions: GUMPY
3,829
1,555
It is not at all irrelevant in that the basic regulators are reducer valves, without incorporating a pressure relief facility.
In the static flow situation, the reducer has to perfectly seal off the supply pressure, or the minutest weeping across the seal will inevitable lead to an increase in the downstream system pressure.
This is recognised in applications were the consequences are not tolerable and the reducer is paired with a relief valve.
In our application where we feed our vans with a portable hose the risks of contamination happening and that flowing on to contaminate and compromise the reducer's seal, are IMO high. That coupled to the high probability that a static pressure of the utilities supply being higher than the design pressure of the van's water system componentry, certainly make me totally unwilling to put our van at unnecessary risk.
4,778
According to Whale their system regulates mains water pressure to nominal 1.5 bar ( max 1.8 bar max) I do have one but used it only once.
Apr 23, 2024
268
206
935
JTQs statement is valid especially as the various elements are connected and disconnected without thought to carefully removing contamination before connection , so any little bits can enter the system and stop the various valves/regulators from completely sealing. I serviced a van the last week or two and there were bits of of the chrome/silver plating which the plastic shower heads are coated with , in the three way drain down valve!, conclusion :- at some time the owner must have drained the system and these bits flowed back down the pipes. They were also in the aerators on the end of the taps. I always turn off the mains feed to the aquaroll when not in the van also the pump gets switched off . Never assume an automatic system will work as expected , things fail, it's the nature of things. Keeps me in a job(part time)
3,970
In addition the the above discussion, I have had to deal with a number of caravanners whos direct water link has failed to regulate the pressure supplied to the caravan causing the caravans pipe work to be over pressurised and and leak flooding the caravan ruining a holiday. The risk is low, but the consequences are formidable. The risk can be totally avoided by using an intermediary water tank with float valve, and the caravans own water pump.
There are at least two other concerns both of which I have had to deal with when customers complained.
The first is the flow of water through a pressure reducing valve is often inferior to the flow available through a submersible pump resulting in poor shower of mixer tap performance.
And the second issues is sites where several caravans are using a direct connection and their combined demand exceeds the the ability of the sites water pipes to supply all the caravans adequately.
Both situations effectively reduce the pressure and flow at the caravan. Using an intermediate tank and float valve prevents this from being a problem.
On balance I now always recommend the use of a intermediary tank system.
