Sky Lights
The skylights on my Sterling Eccles Sapphire (2000) are dirty between the 2 layers. Is it an easy job to change them or take them out to clean?
Kevin Moore
What make are your rooflights Kevin?
Remis have done a recall on theirs due to outer cover separating from the inner.
If they are Heki then I don't know.
Rod,
Don't know. I assume they are the ones fitted when the caravan was built. They certainly are not Heik1. I will have a look and get back to you
Hugh,
That is why I asked the make, Remis and Heki are supposed to be sealed, double glazed units.
Remis have issued a recall for theirs as the outer skin can separate from the inner and pose a danger to following traffic.
