Slowly unwinding
Oct 17, 2010
1,314
561
Has anyone got any ideas to stop my jockey wheel from slowly unwinding on a journey.
Have to stop and wind it up, but it will eventually unwind again.
Sep 4, 2011
546
321
19,135
If the wheel is located up in the slot and it still unwinds after doing tight ,I would use a Bungee round the handle to the hitch so that it cannot turn.
Reactions: GaryB and Buckman
4,473
Hi Dave, try a bungee cord , attached to the
Just about to write the same, make sure the bungee doesn't slip down the winding handle.
Reactions: toad a caravan
Oct 17, 2010
1,314
561
Thanks. All the vans I've had over many years, this is the first one to do it. Very frighting first time it happened.
Sep 12, 2021
569
496
5,135
Just don’t do what I did as we were about to leave West Oxon for Old Oaks… all loaded up and ready to go…. Tighten the jockey wheel handle up…. Then , in true Captain Chaos style, “ *** it up until the handle snaps off in yer hand”
God bless MJ LOVELLS of Highbridge for saving the two weeks holiday… and my marriage!
Now I am only allowed to wear slip ons🤣🤣🤣🤣🤣🤣🤣🥺
Reactions: DaveA1 and Dustydog
Mar 24, 2014
414
127
18,735
Happened to me, arriving at a site. Ended up using the Milenco steps as a temporary rest for the towhitch, while we dashed off to Grantham Caravans to buy a replacement handle, and B&Q for some drill bits and stud extractors, to drill out the bit of stud still stuck in the clamp.
Sep 12, 2021
569
496
5,135
MJ LOVELLS were brilliant… they moved planned work out of the way so they could fix it for us…. And only charged £42.
5,198
Sam and Martin Lovell did an excellent accident bodywork repair job for me last year. Absolutely first class and highly skilled chaps👏👏
Reactions: Steve1962
5,122
We changed our ALKO jockey assembly for a Kartt jockey assembly and never had another issue with it unwinding.
3,953
1,701
Was that one that incorporated their "Turn lock", a special feature which appears to specifically address the OP's issue?
LINK
I thought you used the Alko one with the nose weight gauge, but I could be getting confused already, even this early in the day!
5,198
I wonder why it happens? Never had a problem on a caravan in over 40 years but did lose one on an older car trailer.
Is it an individual manufacturing defect?
How the JR is stored whilst in transit?
Maybe the chassis clamp hasn't been tightened enough? Thus allowing vibration which undoes the JW?
5,122
LINK
Never had the one with the nose weight gauge as advice on this forum was a waste of money as very inaccurate. No idea if it had the turn lock, but it worked for us. On all our previous caravans pre-2017, we never had an issue with the ALKO unwinding?
Jan 20, 2023
1,310
1,164
2,435
I used to have a Brian James car transporter trailer and the jockey wheel on that used to unwind occasionally no matter how tight you did it up. A bungee cord from its handle to the winch stopped it happening but never experienced it on any caravan or trailer since.
3,425
The lack of wheel balancing on caravans causes a multitude of issues relating to vibration - I know that some brands now claim to balance the wheels at the factory but when tyre replacements are needed, some tyre fitters still persist in the old belief that "caravan tyres don't need balancing"
5,122
Correction. Not some but most tyre fitters! We have always had our caravan tyres balanced since about 2005.
3,953
1,701
IMO it is stupid, just because we don't feel the vibrations as we are not travelling in the van, that does not mean it is not happening and shaking the van.
Afterall, the rotational speeds generating out of balance forces are no less with the van than the vehicle that is towing it, quite often where with smaller wheels on vans they would be higher rotational speeds.
The cost for tyre fitting almost always includes the balancing, not been told its cheaper to leave doing that out.
However, I have also had to point out to fitters that I had specifically asked for and want them balanced, whatever they think.
Much the same as I specify, new & HP stems are fitted, only to be told there is "no need". Then, later to surprise them when responding to "what pressure gov", I tell them I want them inflated to 65 psi. Many IME simply don't understand the application.
In an industry that deems a tyre as "new" up to 5 years since manufacture, and then ought to be scrapped at 7 years since manufacture, it is unlikely to understand much about tyres for caravans!
1,314
561
One of the first things I had done, when I bought the van. In fact balanced all my previous Van wheels.
3,953
1,701
I wonder if the reason many van makers don't bother with balancing wheels, is they don't expect us to tow their caravans?
Given their general response to claims for issues that arise from the inevitable consequences of towing, like "you must have hit a pot hole".
5,122
They tried that excuse with us when we had a cracked front. Part of the argument was if they knew it was a pothole due to state of UK roads then there was a design fault somewhere. The repair ws done at their expense although I had to pay about £600 for a £9000 repair as the whole front needed replacing.
